1. Define Your Requirements
Brightness:
Indoor: 800–2,000 nits.
Outdoor LED Digital Poster![]() |
Indoor LED Poster Display![]() |
2. Key Technical Specifications
Pixel Pitch (Pitch):
Close viewing (e.g., retail): P1.2–P3.
Long-distance (e.g., billboards): P4–P10.
Brightness & Contrast:
High brightness (≥5,000 nits) for outdoor use.
Higher contrast (e.g., 3000:1) improves color vibrancy.
3. Structure & Installation
Protection Rating:
