| Item | Self-Adhesive Transparent LED Film | Holographic Invisible LED Film |
| Photo |
| PCB | Use flexible transparent film (such as PET or PI material) as the substrate, and embed micro LED chips (Micro LED or Mini LED) into it with high density. | It is a whole hollow PCB board, using a LED lamps with IC drive integrated in |
| Structure | The LED layer are between 2 layer of gel,  the screen surface is waterproof (not the control board part) | The LED is naked at surface, having good heat dissipation. |
| Flexibility | Better flexibility, can be rolled into a small cylinder | Suitable for fitting large arcs, can not bend excessively |
| Brightness | Regular is 2000-2500nits,  can make into 4000nits for P6.25 P8, P10, P15, P20 | Regular is in 3500nits, can be adjusted to 5000ntis the max |
| Pixel Pitch | 5mm, 6.25mm, 8mm, 10mm, 15mm, 20mm | 3.91mm, 6.25mm |
| Sizes | Standard size in 1000mm wide, can be customized to other lengths (has limitation), but need to charged customization fee. | Standard size has 1000mm, 1250mm, 1500mm. And can be cut every 1LED row. |
| Transparency Rate | Physical &Visual >90% | Physical >80% ; Visual Transparency Rate >90% |
| Installation | Self-Adhesive by using water. The gel layer are anti-UV ones, which are sticked by water . The longer they are pasted, the stronger they are. | Need to use adhesive tape, what we use is 3M300LSE,Automotive grade high temperature resistance. |
