How to select the proper LED poster display?
Selecting the right LED poster display requires careful consideration of display quality, usage environment, budget, and maintenance costs. Below are the key factors and steps to guide your decision.
1. Define Your Requirements
  • Purpose: Indoor or outdoor? Advertising, retail promotions, conferences, or stage backdrops have different needs.
  • Size & Resolution: Choose based on installation space and viewing distance. Ensure the pixel pitch (e.g., P1.25, P1.86, P2, P2.5, P3) provides sufficient clarity.
  • Brightness:
    • Indoor: 800–2,000 nits.
    • Outdoor: ≥3,000 nits (to combat direct sunlight).
Outdoor LED Digital Poster  Indoor LED Poster Display
  • Viewing Distance: Smaller pixel pitch (e.g., P1.2–P3) for close viewing. Formula: Optimal Distance (m) = Pixel Pitch (mm) × 3.
Comparison Between P1.86, P2, P2.5 and P3.076 : The smaller the spacing, the finer and clearer the picture will be when watching from the same distance and playing the same content. (p.s. Please ignore the color difference caused by different batches of products here, because different batches of lamp beads are used.)
3. Structure & Installation
  • LED Poster Display Area Size: Common sizes (640x1920mm, 960×1920mm) should fit your installation space.
  • Usage: One LED Poster used individually or Multiple pieces Linkable to large screen.
  • Protection Rating:
    • Indoor: IP43 (dust-resistant).
    • Outdoor: IP65 (dust-proof & waterproof).
  • Heat Dissipation: Outdoor displays need aluminum casing or fans to prevent overheating.
  • Powering and Wiring : powered by 110V AC or 220V AC, the LED poster comes with a wall outlet plug cord; free moving wireless which is powered by battery.
Battery Powered LED Poster
Plug to wall outlet LED Poster
  • Control System: Supports video, images, PPT, H.265, and 4K input.
  • Connectivity: Wi-Fi/4G/5G for remote updates, or HDMI/USB for local control.
  • Software: Cloud-based management (e.g., BrightSign, NovaStar) for multi-screen control.
