In today’s highly competitive commercial streets and shopping districts, an eye-catching storefront sign is not only the “face” of your business but also a key factor in drawing customers inside. Compared to traditional lightboxes or printed banners, LED strip signs offer higher brightness, flexible content display, and the ability to update messages anytime.
If you want to build your own outdoor LED strip sign, the OD-WS Series outdoor LED modules are a smart, cost-effective choice that makes the process easy and efficient.
1. Why Choose the OD-WS Series
Front Maintenance + Full Protection Structure
The OD-WS Series features a magnetic front-maintenance screw design combined with a fully enclosed IP65 waterproof back panel. This allows module replacement and repairs to be performed directly from the front without dismantling the back of the screen, greatly improving maintenance efficiency. This design is especially suitable for installations with limited rear access, such as wall-mounted or high-altitude setups.
Multiple Pixel Pitch Options
Available in six pixel pitches—P2.5, P3.076, P4, P5, P8, and P10—the series can meet diverse needs from close-up, high-definition display to long-distance, large-screen viewing. Smaller pixel pitches are ideal for displaying detailed graphics and HD content, while larger pitches provide budget-friendly options with excellent long-distance readability.
Standardized Module Size
All modules use the standard 320 × 160 mm format, making them lightweight, easy to assemble, and especially suitable for narrow installations such as above store entrances, shop windows, and mall corridors. Standardization also ensures simpler transport, installation, and future module replacement, lowering long-term costs.
Reliable Outdoor Performance
With ≥4000 nits brightness and up to 3840 Hz refresh rate, the display remains clear and flicker-free even under direct sunlight. A wide viewing angle and high contrast ensure consistent visuals from various positions. The robust construction withstands rain, heat, cold, and other harsh weather conditions.
2. How to Select the Right Model
Different installation environments and viewing distances require the right pixel pitch to balance image quality and cost.
Recommended Viewing Distance |
Pixel Pitch Model |
Feature Description |
2.5 – 3 m |
P2.5 |
Highest pixel density, ultra-clear details; perfect for HD images, videos, and complex patterns; no visible pixelation at close range; ideal for premium displays and stage backdrops |
3 – 4 m |
P3.076 / P4 |
Balanced clarity and cost; sharp visuals at a reasonable budget; suitable for mall entrances, brand displays, and conference screens |
5 – 8 m |
P5 |
Excellent readability over long distances, high brightness, and cost-effectiveness; ideal for pedestrian streets, community boards, and medium-to-large events |
8 – 10+ m |
P8 / P10 |
Larger pixel pitch suited for large text, motion icons, and simple graphics; clear at long range and more budget-friendly; often used for billboards, stadiums, and transport hubs |
Selection Tip:
For mainly text-based content such as business hours or simple icons, choose larger pixel pitches to save on costs.
For displaying detailed logos, product images, or HD videos, opt for smaller pixel pitches for better detail.
3. DIY Installation Steps (For Stability and Best Display Quality)
Follow these steps to ensure optimal performance and safe, efficient installation of your OD-WS Series outdoor LED sign:
① Measurement & Design
Determine the final installation position and measure the available width and height to match the chosen pixel pitch’s viewing effect. Calculate the required number of 320 × 160 mm modules, leaving space for borders and maintenance access. Draft an installation diagram indicating module layout and interface positions.
② Build the Mounting Frame
The frame ensures screen flatness and stability. Use corrosion-resistant aluminum profiles or galvanized steel, ensuring the surface is flat and free from deformation. Plan cable channels for power, control cards, and signal lines during construction. For high-altitude or special installations, reinforce the frame to improve wind resistance.
③ Mount the Modules
Install modules from left to right, top to bottom, ensuring all interface directions are consistent. Use both magnetic mounts and screws for secure yet removable fixing. Check each row’s alignment with a level tool to avoid gaps that affect display quality.
④ Connect Power & Control System
Choose a 5V power supply with 10%–15% extra capacity for stability and longevity. Select an asynchronous control card (USB/network content updates) or synchronous control card (real-time PC playback) based on needs. Avoid stacking control cards too close to power supplies to reduce heat buildup.
⑤ Signal & Power Cabling
Daisy-chain signal cables in order, ensuring correct direction and stable transmission. Distribute power evenly to prevent uneven voltage or overloads. Secure all cables with zip ties, keeping them away from metal edges to reduce wear and interference.
⑥ Waterproofing
Seal module seams with waterproof strips or silicone to prevent water ingress. Install waterproof caps or boxes on external power connectors, especially in wet climates, to extend component lifespan.
⑦ Power-On Test & Calibration
After installation, power on and inspect each module for dead pixels, color mismatches, or loose connections. Adjust brightness, contrast, and color according to ambient light for the best visual effect at the target viewing distance.
4. Usage & Maintenance Tips (For Longer Lifespan and Best Performance)
① Regular Inspection
Conduct monthly inspections for damage, loose screws, cable stability, and waterproof seals. Increase inspection frequency for high-altitude or high-traffic locations to catch and fix issues early.
② Brightness Adjustment
Use high-brightness mode for daytime visibility and lower brightness at night to reduce light pollution, save power, and prolong LED lifespan.
③ Lightning & Surge Protection
Install surge protectors and lightning arrestors, especially in coastal, mountainous, or storm-prone areas, to prevent high-voltage damage.
④ Keep the Screen Clean
Dust, rain, and pollutants can reduce brightness and cause corrosion. Clean with a soft cloth and mild cleaner in dry weather. Avoid abrasive tools or harsh chemicals.
⑤ Environmental & Load Control
Even with excellent weather resistance, turn off the display during extreme weather (typhoons, blizzards, hail) to prevent damage. Avoid continuous full-load operation to maintain safe internal temperatures.
⑥ Address Issues Promptly
If flickering, color inconsistency, or dark spots occur, power off immediately and seek professional repair to prevent further damage.
5. Key Parameters for OD-WS Series Models
Pixel Pitch |
Resolution per Module |
Pixel Density |
Brightness |
P2.5 |
128 × 64 |
160,000 px/m² |
≥ 4000 nits |
~2.5 m |
P3.076 |
104 × 52 |
105,625 px/m² |
≥ 4000 nits |
~3 m |
P4 |
80 × 40 |
62,500 px/m² |
≥ 4000 nits |
~4 m |
P5 |
64 × 32 |
40,000 px/m² |
≥ 4000 nits |
~5 m |
P8 |
40 × 20 |
15,625 px/m² |
≥ 4000 nits |
~8 m |
P10 |
32 × 16 |
10,000 px/m² |
≥ 4500 nits |
~10+ m |
With the OD-WS Series outdoor LED modules, you can easily create a professional, cost-effective storefront LED strip sign that perfectly balances display performance and budget.
Whether showing daily business hours, new arrivals, holiday promotions, or brand ads, the vibrant colors and smooth motion will make your store stand out instantly on the street.
Passersby will notice your message at first glance, stop to look, and become more likely to walk in.
Start now, and let your storefront truly “light up” as the highlight of your street—day or night!
