HOW TO SELECT APPROPRIATE TRANSFORMER FOR 12V LED STRIPS
Step 1:  Calculate the power consumption of the strip you want
–We can calculate each strip’s power by knowing the LED Type and its rated power for each LED. The formula to calculate is Power Consumption = Wattage of each LED*LED QTY of strip Length.
For example, for 100cm long SMD3528, 150LED/roll model, it’s 30LED per 100cm, so its power consumption is 30*0.08= 2.4Watt.
NOTE: This method the data get is rated power consumption.
In real, once the strip be made into a long run, there is voltage drop, which will cause the lost of the power.
The long the strip, the less real power it produce. A 5meter long strip compare to a 1meter strip, same model, the real power will be 40%-50% less.
The shorter the strip, the real power will much closer to its rated.
And again, some maker will use different resistors to adjust the strip output wattage. For example, if the LED component rated is 60mA, to get better lifespan, will use a big resistor, the current of LED will be used less than rated.
A:  Single Chip SMD3528    0.08watt / LED
Note: Now the SMD3528 is replaced by the name SMD2835, 0.1W.
The strip made with this 3528 LED, the models we sell online have:
SMD3528, 150LED per roll, Less Intensity Single Row LED Strip
SMD3528, 300LED per roll, Medium Intensity Single Row LED Strip
SMD3528, 600LED per roll, High Intensity Single Row LED Strip
SMD3528, 1200LED per roll, Double row LED Strip
Strip Model
3528,150LED/Roll
3528,300LED/Roll
3528,600LED/Roll
3528,1200LED/Roll
30LED/Meter
60LED/Meter
120LED/Meter
240LED/Meter
500cm
12Watt
24Watt
48Watt
96Watt
300cm
7.2Watt
14.4Watt
28.8Watt
57.6Watt
200cm
4.8Watt
9.6Watt
19.2Watt
38.4Watt
100cm
2.4Watt
4.8Watt
9.6Watt
19.2Watt
50cm
1.2Watt
2.4Watt
4.8Watt
9.6Watt
1feet(30cm)
0.8Watt
1.6Watt
3.2Watt
6.4Watt
Remark: 1Roll of the strip is made in 5meters (16.4feet). 1feet=30cm. 1inch=2.54cm.
B:  Single Chip SMD2835    0.2watt / LED
The strip made with this LED, the models we sell online have:
SMD2835, 300LED per roll, Less Intensity Single Row LED Strip
SMD2835, 600LED per roll, High Intensity Single Row LED Strip
SMD2835, 1200LED per roll, Dual Row LED Strip
Strip Model
2835,300LED/Roll
2835,600LED/Roll
2835,1200LED/Roll
60LED/Meter
120LED/Meter
240LED/Meter
500cm
60Watt
120Watt
240Watt
300cm
36Watt
72Watt
144Watt
200cm
24Watt
48Watt
96Watt
100cm
12Watt
24Watt
48Watt
50cm
6Watt
12Watt
24Watt
1feet(30cm)
3.6Watt
7.2Watt
14.4Watt
B:  Side viewing SMD335    0.08watt / LED
The strip made with this 335 LED, the models we sell online have:
SMD335, 300LED per roll, Medium Intensity Single Row LED Strip
SMD335, 600LED per roll, High intensity Single Row LED Strip
Strip Model
335,300LED/Roll
335,600LED/Roll
60LED/Meter
120LED/Meter
500cm
24Watt
48Watt
300cm
14.4Watt
28.8Watt
200cm
9.6Watt
19.2Watt
100cm
4.8Watt
9.6Watt
50cm
2.4Watt
4.8Watt
1feet(30cm)
1.6Watt
3.2Watt
Remark: 1Roll of the strip is made in 5meters (16.4feet). 1feet=30cm. 1inch=2.5cm.
C:  Top viewing SMD5050    0.24watt / LED
The strip made with this 5050 LED, the models we sell online have:
SMD5050, 150LED per roll, Less Intensity Single Row LED Strip
SMD5050, 300LED per roll, Medium intensity Single Row LED Strip
Strip Model
5050,150LED/Roll
5050,300LED/Roll
5050,600LED/Roll
30LED/Meter
60LED/Meter
120LED/Meter
500cm
36Watt
72Watt
144Watt
300cm
21.6Watt
43.2Watt
86.4Watt
200cm
14.4Watt
28.8Watt
57.6Watt
100cm
7.2Watt
14.4Watt
28.8Watt
50cm
3.6Watt
7.2Watt
14.4Watt
1feet(30cm)
2.16Watt
4.32Watt
8.64Watt
Step 2: Choose the appropriate type transformer
          A:    Non-waterproof transformer, DC12V,  from 1AMP(12watt) to 8AMP(96watt)
         B:  Non-waterproof Heavy Duty Industrial Series Adapter,  DC12V, from 8.5AMP(102watt) to 30AMP (360watt)
         C: Waterproof LED transformer,  DC12V, from 2.5AMP(30watt) to 8.3AMP(100watt)
Step 3: Select the right AMP
         A: if you ordered 1 reel SMD3528 with 300 LEDs (24 watt), and need a waterproof power supply, then check the Waterproof LED transformer, and choose 2.5AMP(30watt)
        B:  if you ordered 2 reel SMD5050 with 300LEDs  (total 0.24*600 = 144 watt) and just want one transformer to run, then can can choose the non-waterproof heavy duty adapter, and choose  15AMP (180 watt)
PS: The AMPs or Wattage of the power supply must higher than the actual power consumption,  e.g. for one reel SMD3528 led strip with 300 LEDs, the power consumption is 24watt, but we recommend you choose DC12V  3AMP  36watt power supply for it.
If you have any problem, please contact us!
Learning centerNews
